How to use your Milight lights with Google Home.
Back to overview
Also works for LimitlessLED, EasyBulb and Milight lights.
aqandersen wrote 10/14/2018 at 14:17 point
I have the exact same problem. everyting works fine, but when i use the web interface, nothing happens. i tried sniffing packets from the raspberry, and it does not seem to send anything to the wifi-bridge. only traffic is between my pc and the raspberry. my milights and bridges work perfectly otherwise.  is it possible further to control multiple wifi-bridges from the raspberry?
Edit: disregarding the lack of packets i could sniff. the milights sometimes react to me sliding the hue slider. but it only seems to activate some of the "modes" of the lights, i still cantr turn on or off or anything else, wich leads me to believe, the program sends some wrong packets to the bridge. i guess we need the creator to step in :-(
dnuss wrote 12/01/2017 at 14:59 point
Thanks for the tutorial! Unfortunately I cannot get this thing to work. The Milight hardware bridge itself is configured to my WLAN network and working, i followed every step of your tutorial, and can access your milights-bridge in the browser. But when I try to click something in the browser tab (e.g. turn lights on/off), nothing happens with my Milights. In the config.js, I changed the IP, but nothing more. What did I do wrong?
dax_ultra wrote 09/11/2018 at 06:53 point
Same problem ... did you resolve it ?
thx
