3D printed vac form mold for visor
A project log for Halo 4 Helmet ( Size A, B, C )
3D printable Halo 4 Master Chief helmet in various sizes...
bigredfrogbig_red_frog 03/02/2014 at 03:031 Comment
Original STL files are hosted in thingiverse at
http://www.thingiverse.com/thing:217267
As if by magic model a form for the visor in the original model.
Work out where your cut lines are
By looking where it intersects the main model.
Once you have the model, print it.
Spray it.
spray it some more
Have pull handles and screw locators for the peg board
Then pull in pairs out of PETG so the webbing is on sacrificial areas, having first sprayed some furniture polish for easy release.
But first of course heat it on a quartz heater hot box that you can collapse for storage and transport
remove the molds with a bit of compressed air down the side
Cut out with metal shears, its just safer, easier and more accurate than a band saw. Add magnets and drop in place.
Next step is to paint the visor, but that's another adventure...
big_red_frog wrote 03/02/2014 at 13:12 point
Commenting on my own content to see how this works...look it a wiry dangle thing....
