Installation
A project log for RainBuddy
Turns your existing sprinkler controller into a Wifi connected controller that saves water when its going to rain.
alecAlec 06/12/2017 at 05:230 Comments
Installation of the device is easy.
Here is the before photo of a standard Sprinkler controller wired to 4 zones / valves. The white wire is the "COM" wire, common to all zones.
Here we interrupt the COM line with a relay connected to a Particle Photon, creating a WiFi enabled control system.
Installation is easy.
The project box shown is a sample box - the final device, which would be built with a custom PCB, would be much smaller.
