First thoughts
A project log for 1 RGB LED Clock
A clock showing hours and minutes using only one RGB-LED to display the data
Paul SchmitzPaul Schmitz 06/12/2017 at 12:510 Comments
There are two things to think about in this project: Hardware and Software.
The hardware is simple in this case: One RGB-LED or three individual LEDs in three different colors are connected to resistors and a microcontroller (ATTiny?) on analog output.
The important thing on software-side is representing the time on the LED in a format humans can read with easy explanations. Following are my first notices about this.
- There are 12 different hours to display. Assign each one a color. As each LED can be controlled in brightness, it should be easy to find 12 distinguishable colors.
- There are 60 minutes in a hour. Every LED can blink in 4 different patterns, which means 4*4*4=64 different blink combinations. One LED counts quarter hours, and the other two represent a number of minutes in that quarter.
