Super Turbo
Total misnomer for an multi-core 8bit computer
Totally clueless software developer fumbles about with VHDL trying to make an 8bit computer, with a C64 type feeling, on a Nexys4DDR dev board. Obviously, things may change as I discover what I'm capable of, and what's actually feasible
Primary Hardware Project Goals:
  • 2-4 cores of a custom 8bit CPU running at 100MHz with a 24bit address bus
  • 512KB RAM
  • 640x480 GPU supporting an editable 16 colour palette, 70x50 character map, and 10-20 sprites
  • PS/2 Keyboard
  • SD Card for storage
  • Audio Synthesiser
Primary Software Project Goals:
  • Cross-assembler for compiling on the desktop
  • BASIC interpreter
  • Emulator for the desktop
Secondary Hardware Project Goals:
  • Swap PS/2 to USB, and support USB Hubs (assuming this is possible with the USB port on the Nexys)
  • Ethernet support
  • Some form of joystick support (either via USB, or DB9 based via Pmod sockets or something)
Secondary Software Project Goals:
  • C compiler
  • 1 × Digilent Nexys4DDR
View project log
