Hackaday.io Hackaday.io
Recently Updated Most Likes Newest Project Lists
Courses Tutorials Events Hackerspaces Profiles Hackaday.com Tindie Marketplace
Sign up Log in
DockOut
Breakout connector for the Motorola Lapdock for use with an array of devices
LAK132LAK132
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
2 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
511
0
2
0
Team (1)
  • LAK132LAK132
Join this project's team
raspberry pi Samsung galaxy s3 Motorola Lapdock
This project was created on 08/18/2014 and last updated 6 years ago.
Description
Allow an array of devices (Raspberry Pi, Samsung Galaxy S3, etc.) to easily connect to the Motorola Lapdock
Project Logs
Collapse
  • We figured it out!
    LAK132 • 02/24/2017 at 03:11 • 0 comments
    The users over on the Raspberry Pi forum and YouTube have discovered that shorting the sense pin to +5V turns the Lapdock on! Currently looking into creating a custom cable for it, the current one is extremely fragile
  • Tear down and Analysis
    LAK132 • 10/30/2015 at 21:57 • 0 comments
    I have successfully pulled apart the lapdock and checked what each of the large ICs on the main board are. A full list of those and what they do is available on my website: http://kicodora.com/diy/11-motorola-lapdock-500-teardown-and-analysis
    It would appear the problems that we are having (not accepting any input) is either related to HDMI CEC or HDMI HDCP
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
OR
Turn your Pi into a Thread(TM) Border Router that can operate anywhere using a Nimbelink(TM) cellular modem
Project Owner Contributor
Raspberry Pi LTE-Thread Border Router HAT
Rob CrouthamelRob Crouthamel
Buy the Raspberry Pi Zero W V1.3 Development Board at the Best Price only at Robu.in
akanzler007akanzler007
7" 1200x1920 IPS MIPI DSI display for your Raspberry Pi CM4 CMIO board
7" LCD for Raspberry Pi CM4 CMIO
harlabharlab
Use a single adaptive switch to play any video in the library
PlayVideo: adaptive video player
Andrew MitzAndrew Mitz
Going up?
© 2023 Hackaday
Yes, delete it Cancel
You are about to report the project "DockOut", please tell us the reason.
Send message
Remove Member
