Mounting the reluctor pickup, modules, and coils
A project log for Boat Motor Gets Updated Ignition
updating a 1968, 3 cylinder, 55 hp, johnson outboard motor with junkyard parts to have crank triggered distributorless ignition.
duane-grzybDuane Grzyb 07/15/2017 at 02:090 Comments
Some autocad drawings of brackets and pickup wheels were created and cut by a local water jet cutting company. I have found the reluctor pickups to be very reliable and will pick up metal ranging from 1/16 of an inch thick on up. My smallest pickup disk to date is this one, about 4" diameter with 1/4" notches.
