timing control
A project log for Boat Motor Gets Updated Ignition
updating a 1968, 3 cylinder, 55 hp, johnson outboard motor with junkyard parts to have crank triggered distributorless ignition.
duane-grzybDuane Grzyb 07/15/2017 at 02:120 Comments
i have been experimenting with arduino timing contol, but opted for a ready made megajolt solution for this project. it can be controlled using "mechanical advance" algorithms based on rpm, manifold vacuum, or throttle position. I am currently using rpm based advance, but believe tps advance will be the better overall solution to cure hard starting where there is not enough advance.
