next steps
A project log for Boat Motor Gets Updated Ignition
updating a 1968, 3 cylinder, 55 hp, johnson outboard motor with junkyard parts to have crank triggered distributorless ignition.
duane-grzybDuane Grzyb 07/15/2017 at 02:210 Comments
it seems that decreasing fluid viscosity lead to more predictable operation of the transmission. however fluctuating servo position (verified by unplugging the servo in neutral position) leads me to believe that either the 7805 voltage regulator needs more or total isolation from the noisy 12v boat motor electrical system.
