Schematic update with relay
A project log for 3D Shutdown
Autonomous shutdown with Flip-Flop RS for 3D printer.
daveDave 06/28/2017 at 00:100 Comments
It's time to add a relay on the out pin of my Flip Flop.
According to the schematic, i connected the Collector pin to the input of relay:
Now I created a 3D printer file with, at the end of the "final code", I entered the M81 command.
Let me to show you what happens:
When the print finished, the relay open the circuits and the printer shut down.
In the same time the led turn on.
When i press the button next to the led, the printer will turns on.
