I did another test run at Heather Farm in Walnut Creek.
Here's links to the data files the boat made:
(temp on a map) (csv file) (geojson format)
I still would like the boat to automatically upload the data but it's very easy to access right now.
Things to fix:
- Leaks! I think the hull doesn't leak with 2 coats of epoxy, but the hatch seals and the hatch itself are not fully waterproof. Before I go out into salt water I need more waterproofness.
- Sometimes when the motor comes on it auto mode the ESC is out of sync. Since it's a sensorless brushless motor if the motor does not go the right speed it just vibrates. There are throttle time constants that I will try to adjust.
- The boat leans a lot when turning, and sometimes catches a rail and goes straight. Only when going fast, and if the bow is up enough it is fine. I wonder if a shorter rudder would help or if it's just the v-hull. Maybe I'll print a shorter rudder. I can shift the center of gravity by moving components aft too.
