Blimp User Controls (part 1)
A project log for Remote Control Mini Blimp!
Mini blimp flies through hoops! Features 3 DC motors/ propellers, battery charging, and wireless communication.
sophi-kravitzSophi Kravitz 05/18/2018 at 16:220 Comments
I'm going with a joystick for the main controls because everyone knows how to use one. A joystick is primarily used for direction and speed, it should be received well as a participant interface.
I need 6 commands minimum (up/ down/ left/ right/ forward/ back) and the joystick that I chose is made up of 4 microswitches, so only 4 controls. I love arcade buttons, so I decided to add 2 of those.
Inside of the controller is an Adafruit Feather (has an ESP8266 on it) and a battery.
I used Inventor to model this. Already realized that this rev 1 is missing holes for the battery charging and a reset switch. I also should have added screw holes on the bosses to make them less hollow.
I can fix these post print though :D
and started printing last night. It looks good so far!
