Status: nineteen grams
A project log for Remote Control Mini Blimp!
Mini blimp flies through hoops! Features 3 DC motors/ propellers, battery charging, and wireless communication.
sophi-kravitzSophi Kravitz 12/03/2017 at 23:4911 Comments
Rev 3 arrived from Oshpark, and most of the hardware issues are fixed.
I've had so many comments on how to cut some of the weight- thank you!
From your suggestions, I've removed the PCB under the antenna, saving a couple of grams. Great idea!
I've chosen to keep the battery charging on the PCB. In the final piece, there will be a lot of fast changes and I hate swapping batteries while *doing*other*stuff*. Those tiny battery connectors are a total PITA. A really good idea, but no :)
PCB changes in this rev:
Net: 19.1 grams with everything on the board is exactly 3 grams too heavy. I think this is OK, the programming header won't need to be there in the final (-1.2 grams) and there will likely be some other reduction.
Changes for next rev:
Immediate next steps are getting the communications going. I'm following this most excellent tutorial here
Paul Andrews wrote 12/06/2017 at 17:19 point
@davedarko the PSF-B85 (and the A-85) have the antenna on-board. I have made my own board from scratch using an ESP8285. I used a chip antenna and was careful about the trace design and it works fine. If I look at some of the commercial boards, they don't seem so careful, but they still work fine!
Sophi Kravitz wrote 12/06/2017 at 17:42 point
I think I will use a module rather than laying out my own antenna. 😀
deʃhipu wrote 12/04/2017 at 17:38 point
I still can't understand why you are using the huge and heavy ESP-12 module, when there are modules like the ESP-03 which are much lighter and smaller.
Sophi Kravitz wrote 12/04/2017 at 20:34 point
I'll probably change to the ESP8285 on the next rev
davedarko wrote 12/04/2017 at 21:11 point
[Left for readibility but based on brainfart]
I like that idea, but there's less support out there
Paul Andrews wrote 12/06/2017 at 01:33 point
Recommend this ESP8285 module https://www.itead.cc/wiki/PSF-B85
@davedarko Why do you say there is less support out there? It works just like an ESP8266
davedarko wrote 12/06/2017 at 06:22 point
@Paul Andrews wuah, sorry I was confusing the ESP8285 with the ESP14 module that has an STM8 on it. Nevermind, sure ESP8285 makes sense, good luck with the antenna design!
Sophi Kravitz wrote 12/04/2017 at 13:34 point
Thanks Dave! Someone on twitter recommended making a pogo pin fixture for programming. Swiss cheese...maybe, I think that might interfere with the aerodynamics (haha, as if a balloon could be described as aerodynamic)
davedarko wrote 12/04/2017 at 13:55 point
hehe :) thought so too with the aerodynamics ... you never now, maybe it vibrates and whistles with too many holes :D pogo pin stuff sounds good too :)
davedarko wrote 12/04/2017 at 06:42 point
there are locking header footprints, where every second pin is offset a bit. With that you can put in a header when needed and it wont fall out.
You could take a bigger drill to make it a bit more swiss cheese like / voronoi style.
Looking forward to see a blimp fly :)
Sophi Kravitz wrote 12/06/2017 at 17:43 point
Me too, me too 😀 really wish there was a blimp emoji
