Cheap laser tape measure reverse engineering
Rebuilding cheap laser tape measure to universal laser rangefinder
This project describes my work about reverse engineering electronics of cheap (
Video demonstrating results of reverse engineering of X-40 laser tape measure:
Connecting laser tape measure to Arduino:
Portable Network Graphics (PNG) - 446.86 kB - 06/18/2017 at 14:49
Preview
Download
Portable Network Graphics (PNG) - 187.18 kB - 06/18/2017 at 14:49
Preview
Download
Portable Network Graphics (PNG) - 109.12 kB - 06/18/2017 at 14:49
Preview
Download
  • X-40 laser tape reverse engineered
    iliasam09/22/2017 at 19:45 0 comments
    I have bought cheap Chinese "X-40" laser tape.
    I disassembled it and found that it is really contains laser module that I reverse engineered earlier:
    But the module version is "701A", it's not like "512A" that I bought earlier:
    It can been seen that some components are placed at another places.
    I want to continue reverse engineering: measure some parameters like APD voltage, desolder  some SMD components  and measure their values. It can help me to increase parameters of  laser rangefinder module.
  • Low modulation frequency test
    iliasam08/27/2017 at 17:31 0 comments
    I have tried to switch laser modulation frequency to lower frequency.
    I have tested several frequencies. The lowest frequency still was working fine is 25 MHz. I found that amplitude of signal decrease to 0.65 of initial value (at 150 MHz).
    I think that I need to make additional configuration of Si5351 PLL to set modulation frequency to lower frequency. My target is to set modulation frequency to 15 Mhz.
    Why I need lower frequency? To increase unambiguity distance - at 15 MHz is would be 10 m.
View all 2 project logs
dallasnyc wrote 01/02/2018 at 04:14 point
The 512A and 701A seemed to be both made by a company http://www.jrtmeasure.com/
Here is a link to the 703A manual which I believe is the same for the 701A
https://www.dropbox.com/s/q4x5ru2hvwp5bf0/703A%20user%20manual.pdf?dl=0
I am thinking about ordering the 512A DIY kit from AliExpress.
Were you able to use the TX and RX connections to send Commands to the 512A DIY kit? Or is the serial communications locked out. ( I'm wondering why the DIY kit is cheaper than the stand alone TTL module?)
The same question goes for the 701A that came from inside the x40 laser measure.
Are you able to communicate with the 701A module, (using the manual i linked), or is the serial communications locked out?
I got a price or $35 direct from JRT for the 701A, but that doesn't include shipping.
Thanks so much,
D
Thomas Kane wrote 04/13/2018 at 15:47 point
I was playing with a 703A that I had bought on aliexpress as a standalone. Soldering onto the pads was annoying so I decided I wanted the B605B, which has bigger optics for longer range. All of it's connections are through hole. I bought a complete laser tape unit on amazon so I could get it quicker. It appears that the TX and RX are disabled. I emailed JRT and I think they confirmed that only the stand alone units have it enabled. Not sure if the DIY kits would be enabled or not though.
