You may have noticed that in the previous showcase, the leds are very bright. To make this sign more user friendly I added foam on top of the leds in order to diffuse and dim the light. Also everything is now attached to perf board and the result is a small control board for the sign. Unfortunately, my AND gate was damaged so I couldn't use the repeat function for the user input, but the default mode works fine.
