POV Fidget Spinner
This is the obvious next step to the Fidget Spinner, and the last project involving one. I promise.
I'm sure a lot of us have seen persistence of vision displays before. As I kid I even had an "iTop" which was a top that would spin and write different metrics of the top while it spun. I decided to build this into the latest fad, the fidget spinner.
This was a natural course of the way the Fidget Spinner was going. So I had to do it.
8 LEDs run by a shift register, SAMD21 MCu, hall Latches, magnets, whats not to love?
Has a bunch of fun displays like RPM, number of spins, words, all can be reprogrammed in Arduino IDE.
  • 3 × SMT HOLDER FOR 20MM CELL T&R https://www.digikey.ca/product-detail/en/keystone-electronics/3034TR/36-3034CT-ND/4833649
  • 1 × ATSAMD21G18A-AU https://www.digikey.ca/product-detail/en/microchip-technology/ATSAMD21G18A-AU/ATSAMD21G18A-AU-ND/5056473
  • 5 × CAP CER 0.1UF 16V https://www.digikey.ca/product-detail/en/murata-electronics-north-america/GRM155R71C104KA88J/490-6328-1-ND/3845525
  • 1 × IC CONTROLLR LI-ION 4.2V https://www.digikey.ca/product-detail/en/microchip-technology/MCP73831T-2ACI-OT/MCP73831T-2ACI-OTCT-ND/1979802
  • 1 × IC REG LDO 3.3V 0.6A https://www.digikey.ca/product-detail/en/diodes-incorporated/AP2112K-3.3TRG1/AP2112K-3.3TRG1DICT-ND/4505257
View all 29 components
View all 2 project logs
abdulhadichogle7 wrote 09/03/2017 at 23:30 point
Where is pcb diagram?
warhawk-avg wrote 07/31/2017 at 03:31 point
You have plenty of room on the board...the components that can be...should be 0805...the 0402 is WAY to small for hand soldering...
Either way so absolutely incredible
P.S.  For OSHPark....need "cut out" in the bearing spot, otherwise the fab house will not cut it out
http://docs.oshpark.com/submitting-orders/cutouts-and-slots/
Paul Andrews wrote 07/29/2017 at 19:55 point
Where did you get your PCBs made?
David Smith wrote 07/29/2017 at 12:51 point
Great project, going to be building a couple up very shortly! Could you add the bearing part no. and supplier to the BoM?
sohil wrote 07/12/2017 at 11:41 point
Hello,
This is great project, We event printed our pcbs here locally and soldered it using DigiKey components. But will you please explain excat process of uploading firmware in board. We are trying with USB but port is not detected in Arduino Software.
Chad Kennedy wrote 06/30/2017 at 19:24 point
Can you please add a source for the magnets, or at least dimensions?
Sean Hodgins wrote 06/30/2017 at 22:53 point
Oops! I always forget something. Ill add them to the components, but these are them. https://www.mcmaster.com/#5862K75
Ricardo Ferro wrote 06/25/2017 at 15:06 point
if you actually sell this, you will easily become a millionaire
Sean Hodgins wrote 07/04/2017 at 14:44 point
I would say their marketing is bad to be honest. The fact is I don't have the time to make mine as a product or kickstarter right now, maybe in a month or two, but by then it will probably be too late.
bulrush15 wrote 07/08/2017 at 11:33 point
In general, not if the maker can't hit the desired consumer price point. The problem with many Kickstarter devices is they come out way to costly for most people, given the new features they have. Thus the market becomes very small, since it's only leading edge tinkerers, with money, that will buy them.
Having a flashlight powered by body heat is cool, that doesn't mean people will pay $80 for it. Plus it has problems working in some situations.
The biggest market is poor people, not rich people. If you can sell it to poor people, then you will make a lot of money.
ischainmail wrote 06/24/2017 at 12:34 point
This is great, just began my own POV spinner after seeing one my niece had which lit up. Was hoping someone had done a similar project. Looks like it works a charm!
