Camera Test Harness
A project log for Occifer Bob Watcher
Vehicle-mounted camera with panoramic lens to look for emergency services and other vehicular lights.
glebiteglebite 10/02/2014 at 19:090 Comments
The camera test harness is built - just need to attach the camera to the base unit, adjust to centre it and then I should be in shape to start acquiring images.  This project has highlighted a need for a drill press, table saw, and a t-square.  Oh, I drilled the mirror-mast hole with multiple drill holes and then a nearly-fire-starting with a dremel tool.  Hehehehehehehehe....
Yes the little Lego guy can see everything now.  And it's awesome!
