Power
A project log for Kerbal Space Program Control Panel
A control panel for increasing the realism of Kerbal Space Program with manual control, autopilot scripts, and multiplayer mission control.
lukas-vozenilekLukas Vozenilek 08/19/2014 at 02:470 Comments
I have a small power regulator board I put together that will be able to supply 5V to the components and Arduino but I will need a 3.3V regulator for the RasPi. There would be a barrel jack connector on the board that would power the regulators. If I have the time and money I might add a battery in the enclosure that would last a few hours and then require plugging in to charge.
