enclosure.dxfthe vector files to laser cut the body of the sequencer.Some parts go glued, and some other parts go bent with heat. *Updated the the vertical position of the window for the display to match the current board AutoCAD DXF - 2.72 MB - 09/27/2017 at 11:05 |
try1.rarThe files necessary for the Kicad project. Note that in order to use this prototype as a UI via Serial, you need to bypass the two serial wires.PORTD 0 (RX): now is not soldered to the board PORTD 1 (TX): doesn't go to the board either A1 goes where PORTD 0 (RX) used to go A2 goes where PORTD 1 (TX) used to go RAR Archive - 53.53 kB - 09/10/2017 at 19:11 |
plot jobs dip version.rarGerber files for the PCB of the first prototype. Note that in order to use this prototype as a UI via Serial, you need to bypass the two serial wires.PORTD 0 (RX): now is not soldered to the board PORTD 1 (TX): doesn't go to the board either A1 goes where PORTD 0 (RX) used to go A2 goes where PORTD 1 (TX) used to go RAR Archive - 45.47 kB - 09/10/2017 at 19:09 |
