BMP File Output
A project log for NTSC Shield
NTSC Shield for Mojo V3
ryanRyan 06/28/2017 at 03:260 Comments
I did some project restructuring, to include:
The biggest change is the addition of BMP file output to the following test benches:
Below is what you should see for the ntsc_test_tb output, which matches what you'd see on the television:
