Put the capacitive reading code to use.
Started with code from here: https://forum.pjrc.com/threads/31797-Teensy-FSR-based-MIDI-controller
Added a calibration stage where it detects the base capacitance at startup.
Modified it to use this library for smoothing the input: https://github.com/dxinteractive/ResponsiveAnalogRead
Toyed with the charging timing and other variables, and I now have this:
#include <ResponsiveAnalogRead.h>
const int pinCount = 16;
const int velocityThreshold = 65;
const int afterThreshold = 75;
const int velocityTime = 55;
const int afterTime = 200;
const int defaultMax = 450;
const float chargeTime = 2; //rise time for external capacitors in us.
ResponsiveAnalogRead pinReader[pinCount] = {
ResponsiveAnalogRead(A0,true),
ResponsiveAnalogRead(A1,true),
ResponsiveAnalogRead(A2,true),
ResponsiveAnalogRead(A3,true),
ResponsiveAnalogRead(A4,true),
ResponsiveAnalogRead(A5,true),
ResponsiveAnalogRead(A6,true),
ResponsiveAnalogRead(A7,true),
ResponsiveAnalogRead(A8,true),
ResponsiveAnalogRead(A9,true),
ResponsiveAnalogRead(A15,true),
ResponsiveAnalogRead(A16,true),
ResponsiveAnalogRead(A17,true),
ResponsiveAnalogRead(A18,true),
ResponsiveAnalogRead(A19,true),
ResponsiveAnalogRead(A20,true)
int pin[] = {A0,A1,A2,A3,A4,A5,A6,A7,A8,A9,A15,A16,A17,A18,A19,A20};
int note[] = {60,61,62,63,64,65,66,67,68,69,70,71,72,73,74,75,76}; //MIDI notes
const int midiMin = 10;
int pinMin[pinCount];
int pinMax[pinCount];
int pinTimer[pinCount];
int velocityMask[pinCount];
void setup() {
//Serial.begin (32500);
Serial.begin (115200);
analogReadResolution(10);
//analogReadAveraging(4);
// Set baseline capacitance for offset. Read 20, average, set.
for (int c = 0; c < 20; c++ ) {
for (int i = 0; i < pinCount; i++) {
pinMode(pin[i],INPUT_PULLUP);
delayMicroseconds(chargeTime);
pinReader[i].update();
pinMode(pin[i],OUTPUT);
digitalWrite(pin[i],LOW);
pinMin[i] = pinReader[i].getValue();
pinMax[i] = defaultMax;
Serial.print("Offset: ");
Serial.print(i);
Serial.print(" : ");
Serial.println(pinMin[i]);
delay(5);
void loop () {
int value = pinMin[i] - pinReader[i].getValue();
if (value > velocityThreshold) {
pinTimer[i] ++;
if ( value > pinMax[i] ) {
pinMax[i] = value;
if (!(velocityMask[i] & (1 << i)) && (pinTimer[i] == velocityTime)) {
velocityMask[i] |= (1 << i);
pinTimer [i] = 0;
int velocity = map (value, 0, pinMax[i], midiMin, 127);
usbMIDI.sendNoteOn (note[i], velocity, 1);
Serial.print("NoteOn: ");
Serial.print(note[i]);
Serial.println(velocity);
if (pinTimer [i] == afterTime) {
pinTimer [i] = 0;
if (value > afterThreshold) {
int aftertouch = map (value, 0, pinMax[i], midiMin, 127);
usbMIDI.sendPolyPressure (note[i], aftertouch, 1);
Serial.print("PolyPressure: ");
Serial.println(aftertouch);
else {
if (velocityMask[i] & (1 << i)) {
velocityMask[i] &= ~ (1 << i);
usbMIDI.sendNoteOff (note[i], 0, 1);
Serial.print("NoteOff: ");
Serial.println("0");
pinTimer [i] = 0;
Which gives me this on a long press of my test sensor.
NoteOn: 60 : 90
PolyPressure: 60 : 88
PolyPressure: 60 : 92
PolyPressure: 60 : 95
PolyPressure: 60 : 98
PolyPressure: 60 : 102
PolyPressure: 60 : 108
PolyPressure: 60 : 113
NoteOff: 60 : 0
Reading 16 inputs, it's still quite snappy and I have quite a bit of cycles to spare. Now to see if I can multiplex my 16 inputs into 64 with no external hardware. :)
