I killed one of my VL53L0X sensor modules, so instead of just throwing it away, let's do a teardown and take a look inside for your enjoyment.
Here's the chip with the start of the receiver side removed, you can see an IR filter in there on the left:
Taking more away you notice the left side is fully encapsulated to prevent light leakage from the transmitter (this is the collector side; left) and you start to see the die and the other IR filter on the transmitter side (right):
Here are the IR filters:
Removing both IR filters, you see the laser diode on the right and the rest of the die with the detection array on the left:
And here's the chip removed from the board with all the casing removed:
It looks like there is a secondary detection array near the diode for further timing analysis for ToF.
Blair Wyatt
Very good work. It is always interesting to see how things are built.
There's also a teardown of the VL53L1X sensor here too :) - https://hackaday.io/project/25571-mappydot/log/148243-vl53l1x-teardown
HOW did you remove the black gunk?
Just with a sharp scalpel. The casing is plastic.
Chip porn++
Unfortunately Rule 34 applies. Do you have an URL?
oh wow, thank you for sharing that!
My loss is everyone's gain :)
I just wish I had a better camera for the microscope and a higher magnification (this is 15x).
