PCB Delivery
A project log for MappyDot
Micro Smart LiDAR Sensor
bleckyBlecky 07/04/2017 at 12:203 Comments
The PCBs have arrived from OSHPark! They are so tiny.
And a test fit:
The through hole coating on the cut side pins seems decent enough, however I will have to test the strength of it to see if it holds up. It looks to have bonded well enough however.
The plan is to panelise these boards in such a configuration so prevent damage to the pins:
oshpark wrote 07/06/2017 at 02:29 point
Very exciting!
deʃhipu wrote 07/04/2017 at 13:16 point
It seems like the cut is a bit deeper on one side than on the other?
Blecky wrote 07/04/2017 at 13:29 point
The milling does seem a little off on a couple of them, this is just due to tolerances from OSHPark (these boards are pretty small, so it's quite exaggerated). There's not much you can do about it really, it won't affect the operation.
