MappyDot mBot
A project log for MappyDot
Micro Smart LiDAR Sensor
bleckyBlecky 09/29/2017 at 03:451 Comment
Edit: There's now a how to guide for you to work through to set this up.
I've been getting a demo up and running for Maker Faire with the mBot robit and MappyDots:
There is an extension for scratch which will be on the repo shortly, which allows you to connect a few MappyDots up to the mBot, to get it to drive around and avoid running into your legs or run away from your cat.
oshpark wrote 09/29/2017 at 04:07 point
Awesome!
