All the parts for the new design of the robot arrived. The idea of the new design is to use the mainboard as a chassis for the robot. In front on the plow we have the white area so the children can name the robot. The new robot uses the WEMOS LOLIN32. There is still a lot of testing todo, the goal is to use MicroPython on the ESP32. For power it uses the 18650 Li-Po cell, commonly found in laptop batteries. So in case you have an old laptop battery, don't throw it out yet, you can recycle it for your sumorobot!
RoboKoding LTD
