Finished building 4 new sumorobots for testing and using them in workshops. During the soldering and assembly, quite some ideas came up for improvements. Also later while testing the robots some cons came out that could be improved. Check out the list of thought written here. Also worked a bit on the programming interface, making it now possible to connect to 5 robots from one browser makes testing easier and is also useful for the workshops. The hope is to use the same interface for the end user. Happy programming!
RoboKoding LTD
