CERVOMEC Brewing System
A brewing platform that turns malt, hops and water into fermentable wort. Yeast takes care of the rest and then we have beer!
CERVOMEC concept is based upon the following requirements:
* Counterflow HERMS (Heat Exchange Recirculating Mash System) based architecture
* Process controlled by autonomous micro-controller (got an Arduino for this)
* Two optional brewing modes:
 - Interactive mode
- Fully automated end-to-end brewing process, from dispensed ingredients (malt/grist, hops/adjuncts and water) to cold wort ready for yeast pitching
* "Headless" system (no buttons, no display) with two options of UI (User Interface):
- Serial CLI (Command Line Interface)
- IP Networked cross-platform GUI (Graphical User Interface)
* Dedicated server (I have a Raspberry Pi in my drawer) connected to the micro-controller supporting:
- CLI console
- GUI server and related middleware
- Wi-fi networked connection to GUI clients
The physical setup is a modified HERMS setup using an external counterflow heat exchanger instead of an exchanger imersed in the water tank. I expect this modified setup will allow greater efficiency in heat exchange when compared to a traditional HERMS.
  • 1 × Arduino Mega 2560 Currently upgrading from Uno to Mega 2560
  • 2 × Brewing pumps I Got March pumps. Adding second pump for counterflow action
  • 2 × 8 x SPDT relay module
  • 2 × SSR relay And proper heatsinking
  • 2 × Heating elements Water tank and boil tank
View all 10 components
  • The heat exchanger
    renatomsteiner08/20/2014 at 22:33 0 comments
    The new heat exchanger is going to enable precise temperature control along the whole process, running the following tasks:
    * Water tank temperature uniformisation
    * Mash temperature control along mash process and sparging
    * Two-stage wort chilling, fist stage with network water and second stage with ice water
  • Some cool automated home brewing projects / products
    renatomsteiner08/20/2014 at 02:00 0 comments
    Brewtroller
    BCS Brewing Control System
    Picobrew Zymatic
    Brewbot
    Braumeister
  • To-do list
    renatomsteiner08/20/2014 at 01:55 0 comments
    * Hop dispenser
    * New hydraulic and electric setup assembly (almost there)
    * Updated Arduino code according to new setup
    * Software stack for networked GUI (I guess this is gonna be the hard part)
    * Raspberry Pi configured as GUI server
  • What did I have until a few weeks:
    renatomsteiner08/19/2014 at 02:57 0 comments
    * Automated brewing system based on a classical HERMS setup
    * Same water vessel heats mashing wort and chills boiled wort
    * Serial connection CLI (Arduino IDE)
    * Still requiring some minor interferences along the process:
      - Hop additions
      - Fermentor hose connection
    This setup works but I'm unsatisfied with heat exchange efficiency, so I am moving forward to a new setup.
    I started writing a Processing GUI but quickly got frustrated because I was stuck in the server machine by the serial connection. My goal here is to have a network accessible GUI so I can access it through other networked devices.
View all 4 project logs
Kojote wrote 02/24/2015 at 11:59 point
Bit sad that you've stopped working on it after the prize ended
renatomsteiner wrote 03/04/2015 at 02:58 point
Actually I've been continuously working on it and had some good progress. I hope to update it here soon...
Androiders wrote 01/29/2015 at 15:26 point
Love this project! When i get more space i will definitely build a HERMS system :)
