The finished InspectorBot!
A project log for InspectorBot
An open source robot to inspect under vehicles, crawl spaces and any other dark dirty space you need to take a look at.
dennisDennis 10/15/2017 at 12:550 Comments
Here are a few pictures of a finished InspectorBot. Sorry for the bot being a little dirty. It has been out for a few test drives. I have found it is amazingly fun to drive.
The below picture of the front end shows the low definition camera and the forward pointing LEDs.
The top view shows the High definition camera and the upward pointing LEDs.
The side views.
The rear view shows the power switch and the USB charging port.
And last, the bottom view showing the four motors.
