High Definition pics inside and out
A project log for InspectorBot
An open source robot to inspect under vehicles, crawl spaces and any other dark dirty space you need to take a look at.
dennisDennis 10/21/2017 at 04:580 Comments
Front view of low definition camera and forward pointing LEDs
Both sides.
Rear showing power switch and USB charging port.
Top view showing High Definition Camera and upward pointing LEDs.
Bottom view showing m20 gear-head motors.
motor drive board.
Inside the box.
Inside the PI case.
Inside the top of the PI case showing the upward pointing LEDs.
