Uni-polarization by diode bridge insertion
A project log for Very tiny Motor driver with Time-of-Flight sensor
Very tiny DC motor driver controlled by ATmega328 and its operation is sensored by "Time-of-Flight" IR-Laser sensor
microwavemontmicrowavemont 07/24/2017 at 03:350 Comments
The tiny board is totally self-contained by still have a fear of "reverse voltage application". The applied voltage (taken from rail) is directly connected 3.3 V LDO and Motor driver and reverse voltage may destroy the circuit. Indeed this issue can be easily solved by diode bridge insertion between board and rail. By insertion of diode, we don't need to consider the direction of train (polarity applied to board) and just the train will work by "detected information" and "program inside ATmega328". Ease of use is very important for this kind of board!!
