Xbee under microscope
A project log for IoT full stack solution
This is a solution for IoT devices that connect via a pc to internet and send data to a cloud like web application
Dimitris AndritsakisDimitris Andritsakis 07/16/2017 at 08:420 Comments
Now I'm going forward next step which is trying to intercept communications between wireless modules and the base station they are connected. So for that I purchased a Wireless Development Board form NXP the USB-KW24D512 which has sniffing utility built in and can sniff Xbee packets by default. Also you can write your own wireless application for it and run it on its ARM M4 embedded processor.
