Minimum Wall Thickness Fail
A project log for The Hasselquad
Analog Aerial Photography Platform
richard-hogbenRichard Hogben 06/30/2017 at 01:530 Comments
The viewfinder walls are too thin unless the part is printed on something like a formlabs machine. I've already adjusted the model and will see how the existing part turns out but I'm assuming it won't be strong enough. All the walls are now at least 2mm thick. I also took the time to add some fillets on any edges that might be under stress.
