2017 Flashing Light Prize
Blink a lightbulb contest
This is just quick description of how I made my entry into "2017 Flashing Light Prize" contest, not related to Hackaday in any way - see https://www.flashinglightprize.com/
The goal of this contest is - to flash a lightbulb, as simple as that. What counts is originality of solution, so I tried to bring something I've never seen before.
  • How it works
    jaromir.sukuba06/27/2017 at 12:42 0 comments
    This circuit exploits two parameters of key components - temperature dependence of lightbulb and hysteresis of relay - which are usually overlooked.
    When power is applied, relay is not energized, current flows through NC contact and lightbulb goes on. Notice the lightbulb has two filaments - designed for 21/5W car lights
    Here you can see voltages on base of T1 (yellow), collector of T1 (blue) and voltage on 21W filament of lightbulb (purple).
    As current flows through the 21W filament, the another one heats up too. Its resistance rises, so voltage on voltage divider - formed by R1 and filament - starts to rise. This causes transistor T1 to open, collector current increases and voltage on relay coil increases too. When it reaches some threshold value, relay engages, NC contact is open and current stops flowing through the 21W filament. Temperature of 5W filament decreases too, so the voltage on base of T1 decreases. On the other hand, it takes a while for the filament to cool down and as this happens, collector current falls down accordingly. Relay doesn't switch off immediately, but exhibits some degree of hysteresis, so it takes a moment to switch off. This effect and thermal mass of the filament is the main contributor to switching frequency being in range of 1Hz.
    Not how fast the lightbulb heats up (quick rise of T1 base voltage) and cools down slower. When I decrease voltage from 24V to 18V, the voltage rise is much slower - because temperature of filaments reaches lower value - so also collector voltage doesn't have such as high voltage swing. Because the heat-up time is longer, the on/off ratio and frequency changes too. And some more photos:
View project log
