Back in the swing of things
A project log for Chirppp, Serial over LORA
Use LORA via GPIO and a full-duplex serial emulator for serial a connection intended for extended range use.
dominic-demarcoDominic DeMarco 07/18/2017 at 04:070 Comments
I'm still a bit stuffed up but overall feeling much better from whatever summer sickness managed to take hold of me.
I decided to bite off a what seemed to be a small piece of work to do this evening, but here I am, typing this waaaay past my bedtime.
I'd like to start doing some testing of multi threading on this project. I think I might get some better numbers in terms of packet loss if I have a dedicated thread set up to ONLY listening for gpio interrupts and sending a message through a channel to the main thread saying it's okay to read from the serial port.
If I'm still seeing some issues with packet loss I may do some cpu profiling and see what I can make faster. I know that the library I'm using uses epoll under the covers to do edge detection on the gpio. In the end I might end up doing some research on how to get some quicker interrupt detection through sysfs...
I'm hoping that isn't the problem, but when I send 100 packets at the slowest speed from the faster device to the slower device, 3-8 go missing. When I send the same 100 packets from the slow device to the fast device they tend to all make it, so that gives me an uneasy feeling.
Anyhoo, moving on from speculation, tonight I spruced up the error handling and generation of a lot of the functions dependent on detecting these interrupts so I can have a better idea of what's going on, and more importantly, have a thread act intelligently and exit accordingly when an error is detected so I don't have to worry about stranding and children out there.
I wrestled a bit with the way rust returns Results and managed to create one or two new bugs for myself to iron out tomorrow or the next day, but we're on the move again!
Oh, and I ordered this from ebay, if all goes well by the time it arrives I'll have a good reliable codebase to do some range testing with the chip!
Here's hoping the distance numbers for these little radios will look a bit better than their speeds...
