Description
The principle of operation:
- The car drives up to the gates.
- Camera reads the car plate numbers.
- Checks the read number with the database; if it finds one, then it opens the gate and lets the car pass.
- Each car at the gates is photographed, then a photo is sent to the Telegram application with the car plate number and its status.
- Telegram bot has the ability to open and close the gates, take a current photo and add an unknown car to the database.
It's done with Python + Bash + Telegram Bot.
Preparation
For this you will need an RPI3 with the Ubuntu Mate installed. You can get it here: https://ubuntu-mate.org/download/
Installing ALPR library
The easiest way to install
sudo apt-get update && sudo apt-get install -y openalpr openalpr-daemon openalpr-utils libopenalpr-dev
Install ImageMagick
sudo apt-get install imagemagick
Installing dependencies for Telegram bot
sudo apt-get install libreadline-dev libconfig-dev libssl-dev lua5.2 liblua5.2-dev libevent-dev libjansson-dev libpython-dev make
apt-get update
apt-get -y install python-pip
pip install pytelegrambotapi
pip install json
Installing Telegram-cli
Check this link to install and configure telegram-cli in ubuntu.
Relay connection
- Connect relay to RPI 3. In my case I used GPIO23 pin for 1st relay and GPIO26 for the second one.
You can test the relay with shell script, just create a simple sh script and run it:
nano open.sh
chmod +x open.sh
sh open.sh
Paste the code below and run it.
Script code for relay 1:
#!/bin/bash
echo 23 > /sys/class/gpio/export
echo out > /sys/class/gpio/gpio23/direction
echo 0 > /sys/class/gpio/gpio23/value
ping -c 2 localhost
echo 1 > /sys/class/gpio/gpio23/value
Script code for relay 2:
#!/bin/bash
echo 26 > /sys/class/gpio/export
echo out > /sys/class/gpio/gpio26/direction
echo 0 > /sys/class/gpio/gpio26/value
ping -c 2 localhost
echo 1 > /sys/class/gpio/gpio26/value
Connect relays to gates
- Telegram message-send script
- Create .sh script with the following code:
#!/bin/bash
to=$1
msg=$2
tgpath=/home/user/tg
cd ${tgpath}
(sleep 1; echo "dialog_list";sleep 1; echo "msg $to $msg";) | ${tgpath}/bin/telegram-cli -k -W tg-server.pub
Telegram photo-send script
#!/bin/bash
to=$1
msg=$2
cd ${tgpath}
(sleep 1; echo "dialog_list";sleep 1; echo "send_photo $to $msg";) | ${tgpath}/bin/telegram-cli -k -W tg-server.pub
Create 2 files for the main recognition script:
touch log.txt
touch numbers.txt
In the numbers.txt - add all the known car plates numbers.
Order of the numbers.txt should be as follows:
YZO169
RFS961
RFS123
ILAI123
RFS872
Car plate recognition script
- 1st it connects to ip-camera and downloads a snapshot.
- then it renames the snapshot.cgi to .jpg file
- Next step is converting(zooming) the image. This step you should configure by yourself. In my case i used "crop 45%" because my camera was placed to high over the gates. So i needed to zoom the photo so the script could recognize the car plate.
- Rest i hope is clear.
#! /bin/bash
wget -q http://login:password@ipadress/cgi-bin/snapshot.cgi -O /home/user/Downloads/autocheck/snapshot.cgi
mv /home/user/Downloads/autocheck/snapshot.cgi /home/user/Downloads/autocheck/snapshot.jpg
convert /home/user/Downloads/autocheck/snapshot.jpg -gravity Center -crop 45%\! /home/user/Downloads/autocheck/output.jpg
FILENAME=$(alpr -c eu -d -n 1 /home/user/Downloads/autocheck/output.jpg |awk '{print $2}' | awk 'FNR>=2 && FNR<=4')
if grep -Fxq "$FILENAME" /home/user/Downloads/autocheck/numbers.txt
then
echo CAR FOUND!, opening the gates! | while IFS= read -r line; do echo "$FILENAME, $(date) $line"; done >>/home/user/Downloads/autocheck/log.txt
sh /home/user/Downloads/autocheck/relay-control/open.sh 2> /dev/null
sh /home/user/Downloads/autocheck/tg.sh...
Evghenii
torehc
if it is a rtsp stream how to proceed?
