Current Status
A project log for Seeing Space Table
A table to see what mechatronic systems are thinking.
minifig404minifig404 08/20/2014 at 05:090 Comments
The questions regarding the radios and database choice are still open. Regarding the radios, I can just try both and see which one works better. It is a little harder to do that with the database question...
Next step is to order a couple of radios, and start architecting the server-side portion. After that, I can design UI flows, and put together all the pieces. Once I have basic sensor logging and searching done, I can add the video feed, and video processing to identify movement.
For now, rovers are going to be the main focus. I'll add in tweaking for other robot types later.
