The principle of operation:
**This project is still in work. I hope the final version will be more beautiful.
Preparation:
Relay connection
You can test the relay with shell script, just create a simple sh script:
nano open.sh
chmod +x open.sh
sh open.sh
paste the code below and run it
Script code:
#!/bin/bash
echo 12 > /sys/class/gpio/export
echo out > /sys/class/gpio/gpio12/direction
echo 0 > /sys/class/gpio/gpio12/value
ping -c 1 localhost
echo 1 > /sys/class/gpio/gpio12/value
Camera connection
Open the raspi-config tool from the Terminal:
sudo raspi-config
Select Enable camera and hit Enter, then go to Finish and you'll be prompted to reboot.
To test that the system is installed and working, try the following command:
Led Connection
Connect your led to any gpio you want + GND. In my case i used GPIO16 for green led and GPIO26 for red. When you are done, test it:
Create 2 simple python scripts for green and red led with following content:
from gpiozero import LED
from time import sleep
led = LED(16)
while True:
   led.on()
   sleep(3)
   led.off()
   led.cleanup()
led = LED(26)
while True:
   led.on()
   sleep(3)
   led.off()
   led.cleanup()
And then test it. If led's are glowing, then everything works good.
python led.py
python led2.py
Face Recognition Script
Install this module from pypi using pip3(or pip2 for Python 2):
pip3 install face_recognition
Create directory "pic" and "unknown" in Documents for example and place there some face pics of people you know. My case it's ("/home/pi/Documents/pic/") and ("/home/pi/Documents/unknown/").
Create python script with following code
import face_recognition
import picamera
import numpy as np
import os
camera = picamera.PiCamera()
camera.resolution = (320, 240)
output = np.empty((240, 320, 3), dtype=np.uint8)
print("Loading known face image(s)")
ep_image = face_recognition.load_image_file("/home/pi/Documents/pic/ep.jpg")
ep_face_encoding = face_recognition.face_encodings(ep_image)[0]
vl_image = face_recognition.load_image_file("/home/pi/Documents/pic/vl.jpg")
vl_face_encoding = face_recognition.face_encodings(vl_image)[0]
face_locations = []
face_encodings = []
while True:
   print("Capturing image.")
   camera.capture(output, format="rgb")
   face_locations = face_recognition.face_locations(output)
   print("Found {} faces in image.".format(len(face_locations)))
   face_encodings = face_recognition.face_encodings(output, face_locations)
   for face_encoding in face_encodings:
       match = face_recognition.compare_faces([ep_face_encoding,vl_face_encoding], face_encoding)
       name = "<Unknown Person>"
       os.system("python /home/pi/led2.py &")
       import time
       date_string = time.strftime("%Y-%m-%d-%H:%M:%S")
       camera.capture("/home/pi/Documents/unknown/image-" + date_string + ".jpg")
Test it
python facerec.py
RFIDConnection
Pins:
We need this to connect our RFID module to Raspberry pi 1.
$ sudo nano /etc/modprobe.d/raspi-blacklist.conf
#blacklist spi-bcm2708
$ sudo apt-get install python-dev
$ git clone https://github.com/lthiery/SPI-Py.git
$ cd SPI-Py
$ sudo python setup.py install
import MFRC522
import signal
import os
continue_reading = True
MIFAREReader = MFRC522.MFRC522()
cardA = [46,44,187,26,163]
cardB = [176,203,130,124,133]
cardC = [20,38,121,207,132]
def end_read(signal, frame):
 global continue_reading
 continue_reading = False
 print "Ctrl+C captured, ending read."
 MIFAREReader.GPIO_CLEEN()
signal.signal(signal.SIGINT, end_read)
while continue_reading:
 (status,TagType) = MIFAREReader.MFRC522_Request(MIFAREReader.PICC_REQIDL)
 if status == MIFAREReader.MI_OK:
   print "Card detected"
 (status,backData) = MIFAREReader.MFRC522_Anticoll()
   print "Card read UID: "+str(backData[0])+","+str(backData[1])+","+str(backData[2])+","+str(backData[3])+","+str(backData[4])
   if  backData == cardA:
     print "Evghenii"
     os.system("sshpass -p *password* ssh root@10.0.0.60 fbi -T 1 -d /dev/fb1 -noverbose /home/pi/Documents/pic/ep.jpg")
     os.system("sshpass -p *password* ssh root@10.0.0.60 /home/pi/Documents/open.sh 2>/dev/null")
#      os.system("sshpass -p *password* ssh root@10.0.0.60 sleep 2")
     os.system("sshpass -p *password* ssh root@10.0.0.60 killall fbi")
   elif backData == cardB:
     print "Vlad"
     os.system("sshpass -p *password* ssh root@10.0.0.60 fbi -T 1 -d /dev/fb1 -noverbose /home/pi/Documents/pic/vl.jpg")
   elif backData == cardC:
     print "is Card C"
   else:
     print "wrong Card"
     os.system("sshpass -p *password* ssh root@10.0.0.60 /home/pi/led2.py 2>/dev/null")
$ git clone https://github.com/rasplay/MFRC522-python.git
$ cd MFRC522-python
$ sudo python read.py
Button + Telegram
button.py
#!/usr/bin/python
import RPi.GPIO as GPIO
from subprocess import call
from datetime import datetime
import time
import os
shutdownPin = 29
shutdownMinSeconds = 5
debounceSeconds = 0.01
GPIO.setmode(GPIO.BOARD)
GPIO.setup(shutdownPin, GPIO.IN, pull_up_down=GPIO.PUD_UP)
buttonPressedTime = None
def buttonStateChanged(pin):
    global buttonPressedTime
    if not (GPIO.input(pin)):
        if buttonPressedTime is None:
            buttonPressedTime = datetime.now()
    else:
        if buttonPressedTime is not None:
            elapsed = (datetime.now() - buttonPressedTime).total_seconds()
            if elapsed >= shutdownMinSeconds:
                call(['shutdown', '-r', 'now'], shell=True)
            elif elapsed >= debounceSeconds:
        os.system()
                os.system("sshpass -p password ssh root@10.14.0.89 -p1337 notify-send -i /usr/share/icons/gnome/32x32/actions/ring2.png Smart-Intercom Guest_at_the_door")
GPIO.add_event_detect(shutdownPin, GPIO.BOTH, callback=buttonStateChanged)
while True:
    time.sleep(5)
Added pushbutton to Smart Intercom.  It sends you last photo to telegram bot and sends notification to Ubuntu Desktop PC.
In order to disable entrance in specific hours via push-button, i made the following  bash script:
#!/bin/bash
H=$(date +%H)
if (( 7 <= 10#$H && 10#$H < 19 )); then     echo between 7AM and 19PM
sh /home/pi/action.sh
else    echo error
sh /home/pi/error.sh
fi
action.sh - opens the door between 7 am and 19 pm
error.sh - displays restriction image between 19 pm and 7 am error.sh script
#!/bin/bash
DISPLAY=:0.0 XAUTHORITY=/home/pi/.Xauthority /usr/bin/feh --hide-pointer -x -q -D 5 -B black -F /home/pi/error.png &
ping -c 4 localhost 2>/dev/null
DISPLAY=:0.0 XAUTHORITY=/home/pi/.Xauthority xdotool key "x"
P.S to run this script you will need to install xdotool
sudo apt install xdotool
