Here's a picture of the test board running off a CR2032 cell at 33.1 uA - but half of that is just being wasted in the PIC! (see below). This image was taken in a darkened room where the display is easily visible. It appears brighter in the image than in real life, though. In a brightly lit room, it can't be seen at all at these current levels, which are about the minimum the circuit can do as built. Overall, I would judge it to be too dim to be generally useful, unless you were only going to use it in the dark - a portable GPS-synched UTC astronomy clock, for instance (I keep thinking of this one, it might become a project).
The interesting part of the circuit is shown here (not shown are decoupling capacitors):
Each segment of the display is driven by a MOSFET and a 1mH inductor. The MOSFET gates are driven from PORTC of a PCI16F1718 microcontroller. To create a pulse of light from a segment, the corresponding MOSFET is driven, creating a ramp of current in the inductor. Once the desired current has been established in the inductor (just approximated by pulse length), the MOSFET is turned off, and the voltage across the inductor rises until the same current flows through an LED segment. This creates a sawtooth-shaped pulse of current through the display segment.
I used the PIC16F1718 because I had it on hand. Unfortunately, this part has an internal low-dropout regulator that draws 15 uA even during sleep mode (datasheet typical number). In my first tests, periodically waking every 32ms to pulse the segments, the PIC draws 16.4uA even when lighting no segments. Although you can disable the LDO during sleep, you pay a penalty in the wake-up time. I haven't measured it, but the delay is long enough to make the display flicker in a very annoying way. I really need to use an "LF" PIC variant. I like the '1718 overall, so I'll probably pick up some LF's with my next DigiKey order.
So, the first test was a simple assembly program that wakes every 32ms to create a current pulse of 8us. This is the lowest-power TritiLED mode. The code is a simple counter, incrementing the hexadecimal digit on the display every 255 timeouts of the WDT, or about every 8 seconds. This is long enough for me to measure the current draw with each digit displayed. Here are the results for digits 0-9:
Digit | Current (uA) |
0 | 34.6 |
1 | 21.7 |
2 | 31.6 |
3 | 31.7 |
4 | 26.4 |
5 | 29.4 |
6 | 33.1 |
7 | 26.4 |
8 | 36.8 |
9 | 31.1 |
I assume the current draw for digits with the same number of lit segments is slightly different due to the inductor tolerances. The average over all digits is 29.3 uA. Considering that over half of this is wasted in the PIC LDO during sleep, the results aren't that bad. It also means that you might get much more brightness for small incremental current increases.
Notes/Observations
This is the lowest current I can run with this circuit. I will experiment with running higher currents. It looks like something in the 100 uA range would make this display usable.
The red color isn't great for nighttime visibility. I found some very bright green displays (for $7.78 each!) on DigiKey. I think I will have to buy one. They're common anode, which will mean a re-think of the circuit - the easiest way might be to use P-channel MOSFETS. The green color should look much brighter to dark-adapted eyes, and these displays are about 2x brighter even in normal lighting.
The display can't be seen in normal room lighting, unless you add a red contrast enhancement filter. The problem with filters is that even though they improve contrast in some lighting, they always make the display darker. In a dark environment, contrast-enhancement filters make things worse. They certainly do in this case.
@Elliot Williams mentioned possibly just using a current-limiting resistor and PWM to drive LEDs at low brightness. This might be an easier alternative if the supply voltage was stable and always enough to light the LEDs. On the other hand, the inductor scheme can work with supply voltages down to the minimum of the PIC, 1.8V from the datasheet, and somewhat lower (off-label). Even with higher voltages, the inductor scheme might be more efficient than using resistors.
Here is the assembly test code:
#include <p16f1718.inc>
ERRORLEVEL -302
ERRORLEVEL -305
__CONFIG _CONFIG1, _FOSC_INTOSC & _WDTE_ON & _PWRTE_ON & _MCLRE_ON & _CP_OFF & _BOREN_ON & _CLKOUTEN_OFF & _FCMEN_ON
__CONFIG _CONFIG2, _WRT_ALL & _PPS1WAY_OFF & _ZCDDIS_ON & _PLLEN_OFF & _STVREN_OFF & _BORV_LO & _LPBOR_OFF & _LVP_ON
;;; variables
cblock 0x20
digit
counter
endc
;;; reset vector
ORG 0
call SETUP_PERIPHERALS
BANKSEL LATA
movlw .63
movwf counter
clrf digit
MAIN_LOOP:
decfsz counter
bra PULSE
movlw .255
movwf counter
incf digit
PULSE:
movf digit, W
call SEGMENT_LOOKUP
movwf LATC ;; start pulse
;nop
;nop
clrf LATC ;; end pulse
sleep
bra MAIN_LOOP
SEGMENT_LOOKUP:
andlw 0x0f
addwf PCL
retlw b'01111101' ; 0
retlw b'00101000' ; 1
retlw b'11100101' ; 2
retlw b'11101100' ; 3
retlw b'10111000' ; 4
retlw b'11011100' ; 5
retlw b'11011101' ; 6
retlw b'01101000' ; 7
retlw b'11111101' ; 8
retlw b'11111000' ; 9
retlw b'11111001' ; A
retlw b'10011101' ; b
retlw b'01010101' ; C
retlw b'10101101' ; d
retlw b'11010101' ; E
retlw b'11010001' ; F
SETUP_PERIPHERALS:
;; intosc 500 kHz
BANKSEL OSCCON
movlw b'00111010'
movwf OSCCON
;; setup WDT for 16ms timeout
movlw b'00001001' ; 16ms
movlw b'00001011' ; 32ms
movwf WDTCON
;; turn off LDO reg for low-power sleep
;BSF VREGCON, VREGPM
;; select digital I/O
BANKSEL ANSELA
clrf ANSELA
clrf ANSELB
clrf ANSELC
;; set TRIS bits: all outputs
BANKSEL LATA
clrf LATA
clrf LATB
clrf LATC
BANKSEL TRISA
clrf TRISA
clrf TRISB
clrf TRISC
return
END
