Selection of electronic components
A project log for Bracelet for the blind
The solution is leveraging from the available stuff, affordable.
tiendoTiendo 08/25/2017 at 15:310 Comments
I will supply voltage about 7 volt to Arduino pro mini on port RAW. This helps Arduino pro mini measure the battery voltage properly.
I use the voltage boost module.
The module lifts the voltage from 3.7v to 7v2a .
Or module to raise the voltage from 3.7v to the desired voltage.
C2500 Transistor used to turn on / off the charger. 4N60C Mosfet is used to turn on / off power (4N60C mosfet replaces Relay3v3a).
