All electronic components for upgrades
A project log for Bracelet for the blind
The solution is leveraging from the available stuff, affordable.
tiendoTiendo 08/25/2017 at 17:010 Comments
0                  Name of electronic components     Number
 1  HC-SR04 Ultrasonic sensor    1
 2  Arduino pro mini    1
 3  Module increases the voltage from 3.7 v to 7v    1
 4  Battery 3.7v 300mah    1
 5  4N60C Mosfet    1
 6  A1015 Transistor     1
 7  C2500 Transistor    1
 8  Buzzer    1
 9  Micro dc coin vibrator motor    2
 10  Jack DC    1
 11  Adapter 5v1a    1
 12  Button    3
 13  Led    1
 14  Fr107 Diode    2
 15  100k ohm Resistor     1
 16  10k ohm Resistor     7
 17  2.2k ohm Resistor    2
 18  510 ohm Resistor    1
 19  200 ohm Resistor     1
 20  Small wire    1
 21  "C1815 Transistor"     2
