Sample Keyboard
I want to make a sampling keyboard with the parallax propeller
I plan on using the parallax propeller to make a sampling keyboard. Hopefully the functionality will be based on the casio line of sample keyboards as well as the korg microsampler with the possibility of adding some of my own features. For the project I just mainly want to get to the point of playing a sample when the key (touch pad) is pressed and having polyphony (limited polyphony is fine, maybe 3 or 4 voice but hopefully more). Everything beyond that is extra but I do have a lot in mind. Casio sk-x functionality: record sound, sound is stretched across keyboard at various speeds (one shot and loop) reverse? Korg microsampler functionality: same as sk-x trigger loop per key chop incoming sample to group of keys key select per sample (multi-sample instrument or split keyboard/drums/clips) preset banks bit crushing other: effects - scrub, reverse, glitch, delay, pitch bend(speed) ultimately if this goes well I would like to design it as a product
Things I might need:
not sure if I would want to have some SRAM on here for more ease of messing with the data
Might also need an DAC
  • Which object?
    zuul08/25/2014 at 02:00 0 comments
    I think I'm going to try using the KISS WAV player V2 object
    http://obex.parallax.com/object/329
    and the KISS WAV recorder
    http://obex.parallax.com/object/330
    by
    Kwabena W. Agyeman
    there's also a tutorial on playing a wav using prop c code
    http://learn.parallax.com/propeller-c-simple-devices/play-wav-files
    the mic and maybe amp (maybe just transistor or 386) will be like in this schematic
    http://www.rayslogic.com/propeller/DemoSched.gif
    the sd card will be set up according to the code ..there are pull up resistors and a regulator on my sd card breakout
    design may be modified to a similar one if built into a pcb
    I'll use the touch pads on the quickstart board to test
  • 2min vid
    zuul08/21/2014 at 07:00 0 comments
    didn't know if we still needed a vid or not... i'm just uploading this in case
    yeah, i don't say much in it cause i'm just doing it for the vid
  • Starting out
    zuul08/19/2014 at 07:11 0 comments
    I have the parallax propeller quickstart board
    SD card breakout
    electret mic and speaker
    I need to build the mic input circuit and possibly something for the output
    the main problem with my project is going to be the coding, I know very little code and would appreciate any help.. I might make a post detailing how I want it to work
    there are some tutorials i will link to on how to get a WAV file playing on your propeller via SD card
View all 3 project logs
