Flashing Light Prize (2) Rubber Ducky
Bulbous Bulbing Bulbbly
Never...never going to give you up.
This attempt, how ever, shd have been.
Original project had intention of dispensing compressed air in bursts to disrupt the flow...I uh, do/did not have access to such spare equipment. I welcome another 'with shop' to give it a shot.
Special guest hallucinated appearance by @SexyCyborg -- if only. If (long pause) only.
One animal (human) was harmed in the making of this film.
1. Meh.
2. Minor adjustment to the servo delay would have drastically improved the flash rate -- how ever, timing (space use) and operational alterations tested one's patience beyond the threshold of interest (see Notation 3).
3. Moving on...
  • 1 × Arduino Uno
  • 1 × Rubber Duck
  • 2 × Plastic Bowls
  • 1 × Servo
  • 1 × Vinyl Tubing
View all 8 components
  • Piddles
    Vije Miller07/12/2017 at 16:37 0 comments
  • Whirly
    Vije Miller07/10/2017 at 03:44 0 comments
    Used a coat hanger, shaped it around a metal cylinder (bottle), then fed it thru the tubing which while yes impeded the water flow a bit, still allows for a suitable flow for effect. I mean, it's not like this is going to save 147 people on board a flight over the Pacific Ocean...or will it?!
View all 2 project logs
