close-circle
Whirly
A project log for Flashing Light Prize (2) Rubber Ducky
Bulbous Bulbing Bulbbly
VijeMiller 07/10/2017 at 03:440 Comments
Used a coat hanger, shaped it around a metal cylinder (bottle), then fed it thru the tubing which while yes impeded the water flow a bit, still allows for a suitable flow for effect. I mean, it's not like this is going to save 147 people on board a flight over the Pacific Ocean...or will it?!
