Arduino Code
A project log for Animal Interaction
What if you could experience and interact with the world like animals do.
drap-designDrap & Design 08/20/2014 at 22:530 Comments
Below is the code we used to make the Aninteractions jacket work. We started working with the code for the Florabrella (https://learn.adafruit.com/florabrella/code) found on the Adafruit website, and modified and removed this to make it suitable for our use. We also had to download the Adafruit libraries:
Color sensor library: https://github.com/adafruit/Adafruit_TCS34725
Neopixel library: https://learn.adafruit.com/adafruit-neopixel-uberguide
Basically the sensors perform continuous readings and send these to the LED-strips. If the readings indicate "black" or as good as pitch dark, the LED-strips fade out. If the sensors are in mid-air or sense an "ambient" reading, the previous reading (color or off) is maintained until either a color or darkness is picked up again.
The code uses one main sketch with three function sketches. Not really necessary, but we started doing it this way to have a better overview and flexibility (bear in mind, we are designers, not programmers).
Main Code:
#include <Wire.h>
#include "Adafruit_TCS34725.h"
#include <Adafruit_NeoPixel.h>
#define PINA 6
#define PINB 5
#define TPIXELA 80 //The total amount of pixel's/led's in your connected strip/stick (Default is 60)
#define TPIXELB 80 //The total amount of pixel's/led's in your connected strip/stick (Default is 60)
//int switchPin = 10; // switch is connected to pin 10
//int val; // variable for reading the pin status
//int val2;
//int buttonState; // variable to hold the button state
//int lightMode = 0; // how many times the button has been pressed
Adafruit_NeoPixel strip_a = Adafruit_NeoPixel(TPIXELA, PINA, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel strip_b = Adafruit_NeoPixel(TPIXELB, PINB, NEO_GRB + NEO_KHZ800);
// our RGB -> eye-recognized gamma color
byte gammatable[256];
Adafruit_TCS34725 tcs = Adafruit_TCS34725(TCS34725_INTEGRATIONTIME_50MS, TCS34725_GAIN_4X);
void setup() {
void loop(){
Serial.begin(9600); // Set up serial communication at 9600bps
//pinMode(switchPin, INPUT_PULLUP); // Set the switch pin as input
pinMode(PINA, OUTPUT);
pinMode(PINB, OUTPUT);
//strip.setBrightness(200); //adjust brightness here
//buttonState = digitalRead(switchPin); // read the initial state
strip_a.begin();
strip_a.show(); // Initialize all pixels to 'off'
strip_b.begin();
strip_b.show(); // Initialize all pixels to 'off'
if (tcs.begin()) {
Serial.println("Found sensor");
} else {
Serial.println("No TCS34725 found ... check your connections");
while (1); // halt!
// thanks PhilB for this gamma table!
// it helps convert RGB colors to what humans see
for (int i=0; i<256; i++) {
float x = i;
x /= 255;
x = pow(x, 2.5);
x *= 255;
gammatable[i] = x;
//Serial.println(gammatable[i]);
uint16_t clear, red, green, blue;
tcs.setInterrupt(false); // turn on LED
delay(200); // takes 50ms to read
tcs.getRawData(&red, &green, &blue, &clear);
tcs.setInterrupt(true); // turn off LED
Serial.print("C:\t"); Serial.print(clear);
Serial.print("\tR:\t"); Serial.print(red);
Serial.print("\tG:\t"); Serial.print(green);
Serial.print("\tB:\t"); Serial.print(blue);
// Figure out some basic hex code for visualization
uint32_t sum = red;
sum += green;
sum += blue;
sum = clear;
float r, g, b;
r = red; r /= sum;
g = green; g /= sum;
b = blue; b /= sum;
r *= 256; g *= 256; b *= 256;
Serial.print("\t");
Serial.print((int)r, HEX); Serial.print((int)g, HEX); Serial.print((int)b, HEX);
Serial.println();
//Serial.print((int)r ); Serial.print(" "); Serial.print((int)g);Serial.print(" "); Serial.println((int)b );
//colorWipe(strip.Color(gammatable[(int)r], gammatable[(int)g], gammatable[(int)b]), 0);
if(clear <= 150){
function1();
if(clear <= 1000){
function2();
else{
function3();
colorWipe(strip_a.Color(gammatable[(int)r], gammatable[(int)g], gammatable[(int)b]), 0),(strip_b.Color(gammatable[(int)r], gammatable[(int)g], gammatable[(int)b]), 0);
// Fill the dots one after the other with a color
void colorWipe(uint32_t c, uint8_t wait) {
for(uint16_t i=0; i<strip_a.numPixels(), i<strip_b.numPixels(); i++) {
strip_a.setPixelColor(i, c),strip_b.setPixelColor(i, c);
strip_a.show(),strip_b.show();
delay(30);
function1 (Fade out when sensor reading is "black"):
void function1(){
int R = 0;
int G = 0;
int B = 0;
int foutCount=5;
int waitT = 5;
//Fade Out
while(1){ //using an inf loop to be more custom.
//Protect the strand from higher then 255 values
if(R>255 || G>255 || B>255) { break; } //DO NOT DELETE OR ALTER THIS LINE.
//break the inf loop if the color is off
if (R<0 && G<0 && B<0) {
//ReSet the RGB to 0 values.
R=0;
G=0;
B=0;
break;
//update the strip
for(int j=0; j<strip_a.numPixels(); j++) {
strip_a.setPixelColor(j, strip_a.Color(R, G, B)),strip_b.setPixelColor(j, strip_a.Color(R, G, B));
delay(30);
//Decrease by the set amount
R=R-foutCount;
G=G-foutCount;
B=B-foutCount;
delay(waitT);
function2 (Keep last color when sensor reading is ambient / mid air):
void function2(){
uint32_t color; strip_a.getPixelColor(0),strip_b.getPixelColor(0);
function3 (Use sensor reading to change color):
void function3(){
strip_a.setBrightness(255); //adjust brightness here
strip_b.setBrightness(255); //adjust brightness here
