Shielding
A project log for A Cheap 24-bit Differential ADC for Raspberry Pi
Making the HX711 into a more general purpose differential data acquisition module with an interface to Raspberry Pi.
Bud BennettBud Bennett 07/11/2017 at 16:300 Comments
The inputs to the ADC are very sensitive to any kind of electrical interference. I recommend that you shield *everything*!
I wrapped the board in electrical tape and then covered it and the sensor leads with copper foil connected to GND.
This made a huge reduction in artifacts in the signal.
