3D Model
07/29/2017 at 10:22 • 0 commentsPlease Download and share my 3D Model for this 6 Axis Arm. See how it is made, try to Print it, tune it.
Next Step
07/26/2017 at 11:22 • 0 comments3DM6X currently is a completed experimental prototype.
The experiment was a success, next step will be to make a Real Cable Driven Electric Powered Robot Arm.
Ideally with stepper in the base and encoder on the axis.
Different sizes for bottom an top joints.
Different lengths for the structure elements.
Ball bearings for the hinges and and the bending points of the strings.
Different material for the structure.
Strong cables.
Next Step
Strong cables.
Video; How i made this project
07/25/2017 at 19:09 • 0 comments -
So Far
07/12/2017 at 20:23 • 0 commentsIt took me 3 weeks to get this run and it works better than i expected.
This experiment can be useful for another project, or fun.
The structure.
First i had cut the plastic with my CNC machine and make all the features from different sides. I am sure it 3D printable.
The holes for the pull cables must be rounded for minimum friction.The holes for the cables
The cable have to come out at the right spot and the should not pass any corner. I drilled 1.5mm holes and than i use a hot wire to melt the corners round. they lead always into the center hole of the arm.
Thread the cables
Starting from the arm trough the drilled holes and all elements down to the control box where they bend above an arrangement bar to the slider.
I had it complete and now i disassemble the robotic arm for minimizing the weight and some little tunings. New style and futures cumin up in my next log
3D Meister
