Why the SpeakUp Click Module, instead of from scratch?
A project log for Expandable Voice Control for Power Wheelchairs
Video located at: http://youtu.be/3vKLR6mpp8s
karl-wilhelm-wackerKarl-Wilhelm Wacker 08/19/2014 at 16:552 Comments
Karl-Wilhelm Wacker wrote 08/20/2014 at 15:01 point
Since each person 's voice is different, the software of the SpeakUp Click module will let me tailor the vocabulary [any language], and increase the chance of word recognition by having at least two variations of each command word in the data base. Debugging of the setup is easier since I can 'evesdrop' on the data the unit sends to the wheelchair controller microprocessor.
Karl-Wilhelm Wacker wrote 08/19/2014 at 23:37 point
A long time ago, I developed a philosophy that pre-dated Hackaday, that I described as "why re-invent the wheel, when you can steal a hubcap". So rather than attempt to develop a voice recognition module's hardware and software, I felt it was faster and [for time reasons] cheaper to use an off the shelf module, and take advantage of it's hardware and support software.
