FIRST PRINT PARTS 'THE BASE'
A project log for 6DOF Robotic arm
Smart servo based robot arm
dannyvandenheuveldannyvandenheuvel 08/06/2017 at 11:243 Comments
The first pieces are printed, looking good!
With some components assembled.
Sepio wrote 09/17/2017 at 15:52 point
Nice print!
Alex wrote 09/14/2017 at 20:53 point
Hello Danny, what printing properties do you use on your parts? Also, is it ABS or PLA plastic?
Thanks! You're doing amazing work!
dannyvandenheuvel wrote 09/14/2017 at 21:52 point
Hi, it's production-grade thermoplastic abs, higher temp about 305° special nozles, and I always use a second filament for the structures. It's not that cheap but the prints are perfect.
