K.I.T.T. - KNIGHT RIDER badge/brooch
whowhow. whowhow. - formally known as purple rider
just some svg to dxf to board stuff and purple leds and purple boards :)
created board dimensions and stuff with the help of these awesome tutorials:
I sell on Tindie
Order from OSH Park
hex - 2.37 kB - 09/20/2018 at 13:05
Download
REV3_shitty_add_on.zip
latest 0805 version with additional shitty add on header
Zip Archive - 525.54 kB - 06/30/2018 at 15:57
Download
brd - 122.51 kB - 03/13/2018 at 11:56
Download
sch - 311.81 kB - 03/13/2018 at 11:56
Download
Adobe Portable Document Format - 23.74 kB - 03/13/2018 at 11:56
Preview
Download
View all 16 files
View all 6 components
  • Revision 3.1 - updates
    davedarko08/29/2018 at 20:39 4 comments
    I'm nearly through my stock of Rev3 boards and close to another order. There was an issue with the LEDs glowing a bit when the battery was fresh. Two red LEDs in series on a fresh batterie just wasn't enough of a voltage drop. So I sat down and added 4 more 0805 resistors and rewired it completely. Now it should definitely not glow dimly in a "supposed to be off" state.
    old version
    new version
    The SAO connector was moved to the bottom center, but I was too lazy to redo the OSHpark upload - png download cycle again.
  • that shitty add on standard
    davedarko06/30/2018 at 15:56 0 comments
    I've added a little smd / smt 2x2 header to the badge for future boards, kinda liked the idea to power boards over that instead. Just don't solder the battery holder and the clip and everything should fit.
  • 0603 revision of the code
    davedarko02/02/2018 at 20:04 5 comments
    Recently on twitter Jon Raymond asked about a firmware update for the older versions of the badge. My hesitation was big until this point, since I thought the charlie-plexing would take up too much space alone, to integrate animations like I did with the newer 0805 version of this badge. As you can see here, I've logged a bit about the progress over on twitter https://twitter.com/davedarko/status/959491261903310848
    I was able to put 7 animations onto the badge! If you want to try out some other animations on the push of a button, you now can!
    • added 7 animations, cycling through on push of a button
    • removed digitalWrite and pinMode functions and replaced them with setting appropriate registers
    • converted every int to 8bit / 16bit unsigned integers where I could
    Download the hex - file from the download section and upload it to the attiny via:
    #!/bin/bash
    avrdude -c usbasp -p t13 -U lfuse:w:0x3A:m -U hfuse:w:0xFF:m -B 2000
    avrdude -c usbasp -p t13 -U flash:w:KITTiny.ino_attiny13_9600000L.hex
    You need to solder a button between the PB4 Pad and GND and find a good spot to glue it down. Have fun :)
    slow chaser
    fast chaser
    K.I.T.T. persistance of vision (I'm really bad at this)
    cross fader
    cross fader beam
    police flasher
    computing (counting up in binary)
  • 0805 are coming to tindie in 2018
    davedarko12/29/2017 at 21:03 0 comments
    also, new firmware :) I've somehow managed to add 5 animations and a switch button to toggle between them! all still fits into the attiny13a.
  • added 0603 kits to tindie
    davedarko11/30/2017 at 20:00 0 comments
  • Sunday is fun day :)
    davedarko11/19/2017 at 12:54 0 comments
    had some fun with my cell phone, a ukulele and a soldered badge in the wild :)
  • Knight Rider sweat shop
    davedarko11/18/2017 at 13:39 2 comments
    Oh help me Michael Knight! So this started yesterday and I just finished a box of 20 "badges" (gotta be careful around here what to call badge and what not). Some conclusions for the next badge, if I ever tend to be so crazy:
    • only do ten at a time
    • change footprint to 0805
    • there's a spare pin that could run through some modes (fast, slow, pov)
    • Change to two leds per pins
    I stole the idea of processing from tymkrs.com where they put together 10 badges at a time with the help of a lazy Susan. Pretty cool idea and it worked great (unless I forgot I can rotate the assembly line).
    So 7 hours of production and I was able to take this picture:
    Now I'm off to @Tindie and see that I can put up a store etc. I don't have 0603 resistors for kits yet, once they're here I will put up kits as well. Any tindie tips?
  • code for arduino
    davedarko10/01/2017 at 21:05 0 comments
      Based on https://github.com/maltesemanTS1/Charlieplexing-the-Arduino
      http://arduino.cc/en/Tutorial/BitMask
    const int LED_1 = 0;     //LED row 1
    const int LED_2 = 1;     //LED row 2
    const int LED_3 = 2;     //LED row 3
    const int LED_4 = 3;     //LED row 3
    #define PRADC 0
    #define PRR _SFR_IO8(0x25)
    void setup()
      // not sure anymore, attiny13?
      // PRR |= (uint8_t)(1 << PRADC);
      // not sure anymore, attiny45?
      // ADCSRA &= ~(1<<ADEN); // disable adc
    void loop() {
      for (int i = 0; i < 8; i++) {
        charlie(i);
        delay(50);
        charlie(7-i);
        delay(50);
      charlie(-1);
      delay(1000);
    void charlie (int var) {
      pinMode(LED_1, INPUT);
      digitalWrite(LED_1, LOW);
      pinMode(LED_2, INPUT);
      digitalWrite(LED_2, LOW);
      pinMode(LED_3, INPUT);
      digitalWrite(LED_3, LOW);
      pinMode(LED_4, INPUT);
      digitalWrite(LED_4, LOW);
      switch (var) {
        case 0:
          pinMode(LED_1, OUTPUT);
          digitalWrite(LED_1, HIGH);
          pinMode(LED_2, OUTPUT);
          break;
        case 1:
          digitalWrite(LED_2, HIGH);
          break;
        case 2:
          pinMode(LED_3, OUTPUT);
          break;
        case 3:
          digitalWrite(LED_3, HIGH);
          break;
        case 4:
          pinMode(LED_4, OUTPUT);
          break;
        case 5:
          digitalWrite(LED_4, HIGH);
          break;
        case 6:
          break;
        case 7:
          break;
        default:
  • someone got lucky today
    davedarko09/01/2017 at 14:35 6 comments
    So guess how many boards I got in my 10+ proto order at dirtypcbs? 40 pcbs! I have to stock up all the parts now :D
  • already had to sell the first assembled one
    davedarko08/10/2017 at 20:23 0 comments
    And for the money I've bought some more boards, this time black pcbs from dirtypcbs.com though - sorry to every other vendor, but please add eagle brd file support :D Anyway, I wanted to have some black K.I.T.T.s with red LEDs as well.
View all 11 project logs
  • 1
    2. Hand soldering the battery compartment
    Pre-tin one pad, solder the battery holder onto that. Afterwards solder the second leg of the holder.
  • 2
    3. Solder everything else
    just take your time, pre tin one pad, use pliers or tweezers to push a part into the hot solder. Then solder on every other leg or pin of the part.
  • 3
    1. Hand soldering the pin
    Add solder to one pad, use pliers to hold the hin in place and solder everything together. After that use heat the second pad and the clip simultaneously and add solder to fix up the second pad. You need to start with the clip because it takes a lot of heat. It makes sense to let the board cool down afterwards.
View all 3 instructions
sonj97277 wrote 04/10/2023 at 14:40 point
Awesome Great idea
https://hypeapk.com/
mrhectorgibson wrote 02/19/2023 at 18:30 point
That is some intriguing work! (https://famewide.com/)
AVR wrote 03/29/2018 at 13:20 point
now do a Porsche 911 !!!!!
Stephen Ludgate wrote 03/29/2018 at 12:42 point
haha - I have only just realised after having your 0603 board in my OSH Park checkout for months and months that you have a new cool version which allows for charlieplexing and adds a button - the 0603 boards have been made and are on their way, d'oh!! Guess that means I just have to order up some more boards though... right?!! ;-)
Steve
davedarko wrote 03/29/2018 at 13:02 point
If you PM me your address I could send you a kit for free, I'm very sorry for that - there's a hack for the 0603 versions though, with a new firmware version that allows you to have a button and 7 animations as well :)
Stephen Ludgate wrote 03/29/2018 at 15:31 point
Ahh That's OK, my fault! I live in the UK, so it wouldn't be cheap to send. I will probably create the 0603 as they are, and order some 0805 boards, no problem! Thanks for the offer though - very kind! :)
Steve
davedarko wrote 03/29/2018 at 16:33 point
@Stephen Ludgate  shipping fee isnt that bad, around 4 euros
And the board is black ;)
Stephen Ludgate wrote 03/29/2018 at 18:17 point
now you have my interest! Lol! That sounds great, true KITT black too... cool! How do i DM you my details?
ryanhall8 wrote 11/27/2017 at 08:45 point
Awesome!!! Great idea!
bullet force
danjovic wrote 11/18/2017 at 21:10 point
Awesome!! It should be a perfect entry if we had a badge contest here on IO.
davedarko wrote 11/18/2017 at 21:25 point
I'm confused with the meaning of "badge" lately, I'm leaning towards brooch now :D thanks, really appreciate it :)
roger_archibald wrote 08/03/2017 at 20:16 point
Nice!
davedarko wrote 08/03/2017 at 20:25 point
Bastiaan wrote 08/02/2017 at 20:42 point
Awesome! The LEDs are charlieplexed, right?
davedarko wrote 08/03/2017 at 06:54 point
Yes :) uv leds on a purple board, the only way to do it :D
deʃhipu wrote 08/02/2017 at 18:03 point
A beauty! Great idea too. Makes me think about a Cylon head badge...
Oh, and you could do that with a 555! ;-)
davedarko wrote 08/03/2017 at 06:56 point
Hehe totally :)
davedarko wrote 08/03/2017 at 08:19 point
and two 4017s which would make it tough to route with that "massive" 2032 :D
K.C. Lee wrote 08/03/2017 at 09:44 point
Actually there was an analog version that used LM3916 (analog bar graph) and triangular wave (could be from 555).  One could in additional modulate the triangular wave to get the burring effects probably came from light bulbs.
Thanks :) that would have been the next one, but feel free ;)
deʃhipu wrote 08/03/2017 at 11:14 point
Nah, I'm sure you will do it better. Just add "KILL ALL HUMANS" to it ;-)
oshpark wrote 07/19/2017 at 02:41 point
awesome!
