0603 revision of the code
A project log for K.I.T.T. - KNIGHT RIDER badge/brooch
whowhow. whowhow. - formally known as purple rider
davedarkodavedarko 02/02/2018 at 20:045 Comments
Recently on twitter Jon Raymond asked about a firmware update for the older versions of the badge. My hesitation was big until this point, since I thought the charlie-plexing would take up too much space alone, to integrate animations like I did with the newer 0805 version of this badge. As you can see here, I've logged a bit about the progress over on twitter https://twitter.com/davedarko/status/959491261903310848
I was able to put 7 animations onto the badge! If you want to try out some other animations on the push of a button, you now can!
Download the hex - file from the download section and upload it to the attiny via:
#!/bin/bash
avrdude -c usbasp -p t13 -U lfuse:w:0x3A:m -U hfuse:w:0xFF:m -B 2000
avrdude -c usbasp -p t13 -U flash:w:KITTiny.ino_attiny13_9600000L.hex
You need to solder a button between the PB4 Pad and GND and find a good spot to glue it down. Have fun :)
slow chaser
fast chaser
K.I.T.T. persistance of vision (I'm really bad at this)
cross fader
cross fader beam
police flasher
computing (counting up in binary)
deʃhipu wrote 02/02/2018 at 22:08 point
No release notes?
davedarko wrote 02/02/2018 at 23:51 point
hm. no. not sure if they're necessary? basically completely rewritten software..
deʃhipu wrote 02/03/2018 at 08:46 point
But why would I want to upgrade then? So that I had the knowledge that the code blinking the LEDs now does the same thing much more elegantly? Is there any visible difference?
davedarko wrote 02/03/2018 at 09:16 point
okay, I understand now :) is it okay to post it here? I'll just start writing it here :D
deʃhipu wrote 02/03/2018 at 13:33 point
Awesome!
